im trying to convert avi (xvid) files to dvd with tmpgenc and virtual dub, im extracting the wav file first then loading them in the encoder seperatly to encode, but im still having sync problemsany ideas ??
You did check to see that they play ok in the original AVI?
Is the problem a constant amount off? If so then you could adjust the audio delay.I do it all the time as you described and the only problem I had was a bad AVI where all of a sudden the Sync was off. Further checking led me some bad video frames. CLipping the file at that point and resyncing the second clip synced everything up at the with a slight discontinuity due to the bad video frame. If I hadn't already lomg since gotten rid of the original source I could have gone back and recapped it instead. -
Bad frames maybe. What's your source?
"Art is making something out of nothing and selling it." - Frank Zappa -
sorry for late reply ! been busy with new baby
Wot do you mean by source ? file? its a avi file that im encoding to dvd , the sync problem is constant throughout the file , its about half a sec to a sec out , but enough to drive me nuts ! can i alter the audio manually so that its right ? im baffled -
Add a audio offset to it in Virtualdub in 'Audio>Interleaving>Audio skew correction' or in TMPGEnc, 'Source range>Audio gap correct'. It may take some experimentation to arrive at the proper offset.
Video in Virtual dub out of sync
By lituvis in forum Video ConversionReplies: 0Last Post: 7th Mar 2012, 09:56 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 17:47 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 19:45 -
Audio out of sync after running file thru virtual dub
By AORMan in forum Video ConversionReplies: 3Last Post: 2nd Oct 2007, 13:35 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 17:27
