I've purchased the Pioneer A03 dvd recoder, and want to
redo a DVD I have. I have a DVD-R that was made by http://www.lifeclips.com, from a videotape I sent them.
I'd like to redo the menu system, with one of my own
design.
How do i grab the mpeg2 files from this existing DVD-R?
Any help would be greatly appreciated.
Winston
Results 1 to 9 of 9
You can just use your standard rippers to do it.
Assuming that your VOB files aren't encrypted (since you made it), I believe that you can just copy the VOB files off the disc.
Regards.
Michael Tam
w: Morsels of Evidence -
Thanks Michael, so i just use a ripper, and that is gonna
allow me to create menus using something like MyDVD or DVDit PE?
Thats what i've been using to make my DVD titles. I want
to get the MPEG file from the existing DVD, and make new chapter marks, etc.
I've never ripped a DVD before.
WInston -
Look, I have never done this before but to get the vob files off your DVD and onto your HDD (for editing/authoring with your DVD authoring proggies) you normally use a DVD ripper (e.g., SmartRipper or DVD Decrypter).
However, since you are using an existing DVD-R, I would assume that this was a self made DVD? If so, the VOB files are most likely not encrypted. If this were true, then you an just use Windows Explorer to copy the vob files off the disc and onto your HDD (i.e., you wouldn't need a ripper at all).
Regards.
Michael Tam
OK, i wasnt really asking about the 'ripping' part, but i guess i was not aware that my authoring program would allow me to use the VOB files, like I would an MPEG2 file.
I'm using MYDVD and DVDit PE version 2.5
WInston -
I have been struggling with the same thing! I burned a video and I need my original MPEG-2 files back! I was able to rip the VOB files, but I don't want them. I want the MPEG-2 file. I don't even care if it's Demuxed or not. The only way I can figure out how to get a MPEG file again is to use DVD2AVI with TMPEGEnc to re-encode the VOBs (.dv2) into new MPEG files. But I really don't think I should have to re-encde my files all over again and make the picture worse.
So if anyone knows how to get my original MPEG-2 files back please let me know! It was so easy to get my MPEG-1 files back from VCDs, I just can't imagine I can't take them back out of the VOB files.
Barney
Ok Ok Ok, I know I'm not as smart as all of you. But look how much smarter I make you look! -
winman32: you can use smartripper to demultiplex the video and audio(to a mv2 and ac3/wav/mpa file) so you can reauthor the dvd again...but i'm not sure that smartripper can copy unencrypted dvd but you can try...read the first step in this guide Vobsnoopy http://www.vcdhelp.com/DVD2DVD-R%20bigger%20than%204500%20megs/
or else can you use vob snoopy to demultiplex the vob or you can find some freeware command line tools at http://www.doom9.net that can demultiplex vobs also.
and you dont need to multiplex the video and audio again because that will the authoring application do.
How to easily convert .ts files to Mpeg2 or DVD
By renzo2000 in forum User guidesReplies: 0Last Post: 25th Aug 2010, 17:03 -
stand alone dvd player and mpeg2 files
By sportflyer in forum Newbie / General discussionsReplies: 7Last Post: 17th Feb 2010, 08:34 -
DVD (VOB) files to mpeg2
By maxamillion in forum DVD RippingReplies: 7Last Post: 18th Dec 2008, 00:37 -
How do I replace audio in MPEG2 (DVD) files using Freeware?
By semmel in forum EditingReplies: 2Last Post: 28th Sep 2008, 21:16 -
joining DVD mpeg2 files without re-rendering
By cheeseplease in forum EditingReplies: 4Last Post: 10th Aug 2007, 13:10
