You're going to spend countless hours to fix something, but all you'll accomplish is to make it marginally better.
I would not bother with this sort of project. It's wasteful.
There's really next to nothing you can do when overexposure and underexposure is the problem.
Results 31 to 33 of 33
Large changes may not be possible but you can apply a small amount of brightness and then some smoothing to reduce the grain. I've done it on videos and it is does make enough of an improvement to make it worthwhile. You can brighten an image enough to at least bring the subject out of the shadows enough to at least make them recognizable. Of course it will not match a properly lit video.Originally Posted by lordsmurf
It shouldn't take long to do. The trick is to only make small changes because that's all that is possible with a poorly exposed video. -
It would be easier to reduce the sharpness value on the tv set, and up the brightness a bit on the tv set.
Do that when viewing this video.
Sometimes just adjusting the tv temporarily will work as good as, if not better, than spending forever restoring a video.Want my help? Ask here! (not via PM!)
noising capture
By backslash in forum LinuxReplies: 6Last Post: 28th Jun 2010, 21:33 -
Brightening a DVD
By RAN1DOM2 in forum EditingReplies: 3Last Post: 9th Aug 2009, 16:20 -
brightening dark MPEG-2 skin tones without brightening anything else
By rch15 in forum EditingReplies: 4Last Post: 18th Aug 2008, 02:53 -
Dark Video
By jan9ella in forum RestorationReplies: 14Last Post: 27th Jun 2008, 15:43 -
brightening color
By Russo in forum Newbie / General discussionsReplies: 4Last Post: 8th May 2007, 15:44
