Hi I have a LG RH7521W HDD/DVD Recorder. However I realised that when I burn the movie into a DVD , it will auto create a menu. How can I exclude the menu when burn to disc so that my DVD will not have any menu. So once loaded, it will just play the movie straight away. Your help would be much appreciated
Use (and finalize) an RW.
Rip the RW with DVDDecrypter.
Stream Process out the menu(usually shows up as a subtitle).
Reauthor without the menu.
Assuming you have a burner in your computer....if not...you are S.O.L.
cause DVD Recorders create menus.
help please - Newbie Can't get Maganvox DVD Recorder Menu
By Novice20 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2011, 20:28 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
DVD Recorder with Custom Menu
By NightFire in forum DVD & Blu-ray RecordersReplies: 32Last Post: 11th Dec 2007, 16:46 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
