Ive converted sum vhs video to dvd but finding the the menu options in tmpenc author a bit basic, are there any templates i can use or is there a specific giude to doin something better?
I have checked the search but couldnt find wot im looking for.
Thanx
Cheers
Jaffa -
Have a read of this, especially gadgetguy's post about halfway down
https://forum.videohelp.com/viewtopic.php?t=278650&highlight=tda+templates
And this one for further reading
https://forum.videohelp.com/viewtopic.php?t=298132&highlight=tmpgenc+templates
TDA is a fairly simple, beginner level authoring tool. If you want more templates or more freedom then you need to look at something with more features. Ulead DVD Workshop 2 or DVD Lab Pro would be good starting points.Read my blog here.
OTOH you can make your own menus and add them as Video (motion menus) or a still image. Pick an appropriate type of button and then resize things like the images TDA creates for each title and drag them to a corner where they won't show, Put the text box that is created with each title by the program, Fill the box with spaces and move them to where their functionality will match the menu you created and author. You can make things really small, put them in the corners or along the bottom where they'll be hidden in the TV sets overscan. If you move the play all button off screen it will still function when you press select.
Doing it this way you can make some really nice menus or for one movie on a DVD you could do a screen cap of the title and use it as the background for your menu for example
Which software to author BluRay and create menus?
By eummagic in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2011, 04:16 -
File output issue from TMPEnc Author Works, VOBs -> single MPEG2
By aln688 in forum Video ConversionReplies: 4Last Post: 10th Apr 2010, 21:17 -
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 07:23 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36 -
Create new menu to link to existing menu. Possible?
By Noy2014 in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 13:22
