What are some of the best ways to eliminate the echoes (if that's the right term to use) of a stretched audio track? I tried experimenting with this using the Pitch Shift effect to lower the audio to the appropriate tone, and in the process use this plug-in to help lessen the echoes in the audio. I think this works ok, but are there better ways to do this? I'm trying to get a much more smoother sound with no echoes and with the right low-tone voice. I think Pitch Shift helps with the tone, but I'm still searching for an answer for my audio echo problem.
Stretching more than 10% becomes difficult. Using the time stretch facility is sound forge, pitchshifting does not become necessary, and the results can be very clean, even past 10%. But it is also dependent on the original quality, to some degree.
How much of a time stretch are you attempting ?
What method are you using ? If you are simply dragging the end of the track out, try using the non-realtime timeshift feature insteadRead my blog here.
I'm stretching it out by dragging it (stretching it to its max). Do I apply the Non-realtime feature first before dragging? I only use the Pitch Shift to lower the tones of the voices in the audio, unless this feature automatically does it for you?
Slow Motion Disable Resample Sony Vegas Pro 10
By bilalarabaci in forum EditingReplies: 1Last Post: 2nd Jan 2011, 14:55 -
When i render to dvd in vegas, the output video plays in slow motion, why?
By shadowofanubis6 in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2010, 18:41 -
Slow motion problem in Sony Vegas 9
By plisb in forum EditingReplies: 4Last Post: 16th Dec 2009, 09:32 -
How edit a clip to play @ 1/2 speed (slow motion) in Vegas 8 plt.
By Jensen in forum EditingReplies: 7Last Post: 12th Feb 2008, 13:23 -
Slow Motion
By sbuckmybballs in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2007, 03:16
