I just bought a divx player and got a bunch of anime in OGM format. I was wondering if anyone can link me to a guide to convery OGM to avi so I can play it on my divx dvd player.
Depends if the video is ok, what audio the files use. How many audio streams, subtitles, etc.
Basically if the video is ok, the audio is vorbis and it has only one stream or you only want one, then you can use mencoder.
mencoder.exe -ovc copy -oac mp3lame -aid # -noskip input.ogm -o output.avi
If it has softsubs, then you need to use ogmdemuxer or similar to demux. Then if your player supports external textsubs, just name the same as the avi and you should be done.
If the file has hardsubs, then they are probably going to be cut of by the overscan of your TV.
How to convert MKV to AVI or OGM to AVI using mencoder
By Baldrick in forum User guidesReplies: 75Last Post: 17th Dec 2013, 11:19 -
How to convert matroska MKV to AVI or OGM to AVI
By Baldrick in forum User guidesReplies: 211Last Post: 13th Apr 2012, 00:56 -
OGM to AVI/DVD
By liveforit11 in forum Video ConversionReplies: 3Last Post: 20th Aug 2007, 21:20 -
Convert ogm to avi please?
By venus in forum Video ConversionReplies: 13Last Post: 11th Aug 2007, 17:15 -
OGM/SSA to AVI
By defiancexr in forum Video ConversionReplies: 2Last Post: 14th May 2007, 23:33
