Greetings!
I'm curious if any 2000 Expert users are having problems with
recording TV "after" you've upgraded your drivers or application??
My TV card worked flawlessly until I upgraded. After the upgrade,
the sound and video get out of sync, about a minute into the recording,
and it gets worse the longer you record. Eventually, the video starts
jerking.
I uninstalled the software and re-installed the original software from
the CD......and everything worked fine.
Thinking there may have been something went wrong during the
download and update, I downloaded the updates again.
Same problem as before....the sound and video are out of sync.
I should mention, this sync problem occurs when using Mpeg-1 or
Mpeg-2. WMP and AVI works okay.
Question is: is there a problem with the application upgrade or
the drivers upgrade.....or both??
As for now, I uninstalled the software again and re-installed it
from the CD and everything is working okay.
I'm tempted to leave well enough alone and forget about upgrading.
However, it would be nice to know what's causing the problems and
let someone at Leadtek know.
If any Winfast users are having problems after an upgrade,
I'd like to know.
Thanks,
Roln
I've got leadtek winfast pvr 2000 xp expert version 3.0.10.85 winfast fm 5.13.01 2006-2.99 using driver 4.0.107.3204 never had any problems with it.
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 11:32 -
Winfast tv 2000 xp
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 21st Jun 2010, 12:38 -
Winfast 2000 XP input jack is a PS/2?
By jabberdau in forum Capturing and VCRReplies: 7Last Post: 18th Nov 2009, 14:46 -
Windows 2000 Questions
By dafoe in forum ComputerReplies: 2Last Post: 21st Dec 2007, 16:31 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 11:00
