Hello!
is anyone doing batch encoding? I've been using instantcopyhiddensettings to do batch, but I was wondering what else was out there.
thanks!
-Josh
	I dont call it batch ... I call it "freakin nightmare" ..
 Avi2dvd by Trustfm has batch encoding , plus more ... only got it today and giving all the feature's a spin .
 Has avi , ogm , mkv and wmv batch encoding ... more than enough to poke a stick at , and dvd input .
 Ntsc to pal , pal to ntsc , 16:9 or 4:3 , ac3 , auto chapter or list , output dvd , svcd , vcd ... encode using quenc , freeEnc , nuenc , hcenc , cee .
 Multiple audio , sub's ... and a menu designer ...
 I might be here for some time yet ... quenc in dualpass mode ... still waiting to see if this program make's a stuff up with final output .
 Nope , I still prefer dvdauthorgui ...
 As for batch file's used for encoding ...
 1: Still's to m2v
 2: Wav to ac3
 3: Mpeg1 demuxing (also muxing)
 4: Multiple iso generator
 5: Avi to m2v (352x288 , pal) using bbmpeg as encoder of choice
 Many more .
 Then there are automation script's to call and run other program's to perform job's while I am away from the pc for a couple of hour's .
 Batch encoding dvd's to mpeg4 (several on hd ready to go)... These are generated using autoit ... good for batch rm media conversion's via avisynth script .
 Super also dose batch encoding , handy for mov's , and other format's ... can help with stubborn file's that refuse to be re-encode using other converter's .
	If you mean encoding to Mpeg2 for DVD for example I use TMPGEnc 3 Xpress which has a batch tool. It can also do the other way to AVI for example. Or I use TMPGEnc Plus which has batch function too.
 That is encoding, What I suspect you mean is shrinking multiple DVDs to DVD5 size. To me although it can be done by encoding at a lower bitrate, to me that is shrinking and turning for example DV video into dvd authorable (or Divx/Xvid) is encoding.
  New batch encoding solutionBy grv575 in forum Video ConversionReplies: 0Last Post: 6th Jan 2010, 17:58
  Batch encoding .. HELPBy likwid8 in forum Video ConversionReplies: 6Last Post: 30th Jan 2008, 13:33
  Batch encodingBy buddycat in forum Video ConversionReplies: 1Last Post: 29th Oct 2007, 06:12
  Batch Encoding with tmpegcBy Shaba1 in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2007, 08:38
  Batch Encoding - TV EpisodesBy redtrigger in forum Video ConversionReplies: 25Last Post: 9th Aug 2007, 11:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
