Just got a Lite On SHM-165H6S. I can read and write + - DVD's, CD's and use Light Scribe. But I can only read DVD+ - RW's. I can't erase them to write on. I'm using Nero 6.6.0.17 that came with the drive. Help. Thanks.
Results 1 to 9 of 9
Although I don't always advocate this, have you checked to be sure you have the latest firmware? Maybe the old stuff was buggy.
www.rpc1.org -
Originally Posted by Beams
http://codeguys.rpc1.org/firmwares.html
have you tried using other burning programs to erase the DVD-/+ RW media? DVD DECRYPTER can erase rw media. -
Tried Nero, DVD Decrypter and DVD Info and none work. They work for my Plextor 712.
Used a Maxell 1x and a Fuji 4x. -
Hmm,well I have a LiteOn SHM-165P6S (Non Lightscribe) with codeguys (MS0M - stock) firmware and it reads and rips great.Good CD/DVD error correction and fast DAE speed.I only use it for ripping because it's writing quality is awful IMHO,that's where the LG GSA 4167B comes in.The LiteOn is also nice for disc quality scans with K-Probe.
As mentioned,try CodeGuys LiteOn SHM-165H6S (HS07 -Stock) firmware flasher~Luke~ -
That's a strange problem. I use dvd-rw a lot on my 165H6S but strangely I can't recall erasing one. I primarily use rw for transfers from a set-top dvd recorder and reformat/erase on the set top unit. Does this behavior happen on new media that was originally recorded with the 165H6S or just media previously written on another burner?
Just received another burner from Newegg and everything works. This is the 3 one and built in March 06 the other 2 that didn't work for dvd-rw +or- were built Feb 06.
Lite-On Burner Will Not Read DVD+R Media
By kca741979 in forum MediaReplies: 11Last Post: 28th Feb 2010, 01:47 -
How do I burn a dvd with nero using ffdshow from k-lite pack
By sxpredman in forum Newbie / General discussionsReplies: 7Last Post: 7th Nov 2009, 01:20 -
Why does my Lite-On DVD burners fail on 8x DL discs?
By Onceler2 in forum MediaReplies: 26Last Post: 5th Jul 2009, 01:11 -
Lite-On A110 DVD recorder, problem with RW discs
By Jack_Dante in forum DVD & Blu-ray WritersReplies: 1Last Post: 7th Apr 2009, 09:50 -
Anyone have Lite DVD Recorder On DD-A100GX ? ? ? ? ?
By HolyGeez in forum DVD & Blu-ray RecordersReplies: 8Last Post: 30th May 2007, 08:58
