Hi can anyone help?
I'm converting AVI's to DVD using WINAVI and 50% of the time the outputted files are having distortion every other second in the picture. The AVI's are problem free when played through Windows media player and Nero showtime. I've tried outputting in Auto/NTSC/PAL frame rates. AUTO causes distortion and NTSC/PAL make it jitter like the film is robotic. It's the same when it is burnt to DVD and played on TV. I've also tried Nerovision 4 and the same happens. No distortion but robotic frames. Do i need to reconvert the AVI's????
Help Please!!!!!!!!!!!!!!!
give us more information about the source file, what is the video codec and framerate? use avi2clipboard.
and try convert with convertxtodvd. -
in this example the frame rate is 25 frames per sec and its a xvid codec.
it shouldn't cause any problem if you convert to PAL. Try ConvertXtoDVD!
Does the converted DVD look okey on your computer using a software dvd player? -
no. once converted to DVD files they are jittery or distorted when played on computers dvd software. Ill try the convertxdvd program and see if that helps. Its maddening cause some are excellent quaility but more and more are going like this!!!!
I also have the same problem but this is with 7.5. Never had it happen to me with 7.1 at all. I did uninstall 7.1 before installing 7.5. Seems like it is doing this with all the avis and even mkv to dvd.
I also tried the latest convertxtodvd but it was very slow compared to winavi.
Hmm wish I could find a screenshot program to show what the picture distortion looks like under the preview.
Anybody experiancing this on 7.5? -
Originally Posted by lyricaldanichan
Jittery Flickering!
By Soixante in forum ComputerReplies: 4Last Post: 27th Sep 2010, 06:11 -
DVD To Xvid - jittery, please help?
By kpoman in forum Video ConversionReplies: 5Last Post: 25th May 2010, 17:59 -
jittery slow motion scenes
By Dr_Layne in forum Capturing and VCRReplies: 1Last Post: 25th Aug 2007, 19:36 -
burning avi file is jittery
By fredted40x in forum Video ConversionReplies: 1Last Post: 4th Jul 2007, 11:48 -
Jerky, Jittery DVD
By leng in forum Newbie / General discussionsReplies: 18Last Post: 24th Jun 2007, 10:15
