@ 2GB per hour XviD can be as-good-as/even-better-than Nero Digital.
				Results 31 to 32 of 32
	I've encoded some 1.5-2-hr movies to 1-gb size with ND and found the results to be terrific. So, I'd think a movie of the same length encoded to 4.2-gb would be indistinguishable from the original, since I hardly can tell the difference at 1-gb. (The encoding bitrate is typically over 1-gb, especially for the shorter movies.)
 I'd think encoding to 4.2-gb ND MP4 would be wasting a LOT of disc space if all you want is the movie. However, using the various "shrink" softwares (non-ND), you do end up with a DVD-compliant version vs. ND's proprietary MP4 version not playable on many standalone players (see www.avayon.com, which may or may not be available in BC).
 And, these "shrink" softwares can encode the entire DVD9 (movie and extras) to DVD5 with usually no worse than "acceptable" visual degradation except for very long movies.
 As always, "quality" is in the eye of the beholder.
 My bet: Movie only, the ND MP4 would look better if burned to a DVD5, but maybe not enough better to sacrifice DVD compatibility.
 You've aroused my curiosity, though, since I have an Avayon player . . . . Might just have to do a comparison . . . .
  Need a *good* software for converting MP4 to AVI ..By ahmadka in forum Video ConversionReplies: 6Last Post: 24th Nov 2010, 16:44
  I'm looking for a good MP4-2/H264 video encoder which should NOT be based oBy clipperyoungamerica in forum Video ConversionReplies: 7Last Post: 19th Mar 2010, 17:54
  A good size of flash mp4 file on a pageBy Cazz in forum Video Streaming DownloadingReplies: 5Last Post: 20th Dec 2009, 14:40
  What are good specs for a high-quality MP4 file? (Will look good on my 40&qBy HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18
  How good are MP4 camcorders?By OM2 in forum Newbie / General discussionsReplies: 2Last Post: 20th Feb 2008, 01:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
