Using "VOBblanker" I seemed to of blanked out the wrong cells and now the menus no longer work and only loop and do not point to the movie...
The moive is on the disc!
Is there anything short of re-backing up from the orignal to fix my error?
--David
VOBblanker creates a backup folder, so the original files are still there, unless you deleted the folder. You could go back to the backup folder and fix your mistake.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Originally Posted by Dv8ted2
Originally Posted by rkr1958
Originally Posted by rkr1958Believing yourself to be secure only takes one cracker to dispel your belief.
I am to use to using a 'GUI' programs that does all this behind the screen programing....
So I will just start from the orignal source and just make sure that the out-put file will play before burning to DVD and deleting the work folders...
windows 7/vista... opps i know.
By pat82 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2010, 23:52 -
can unnecessary VOB cells be not only blanked but deleted?
By q3mi4 in forum Newbie / General discussionsReplies: 0Last Post: 30th Oct 2008, 09:01 -
Extract Cells from dvd with memcoder
By banon in forum LinuxReplies: 0Last Post: 2nd Oct 2008, 01:15 -
Chapters or Cells
By wulf109 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 16:40 -
DVD Lab Pro - 2 cells issue
By GangstaRap in forum Authoring (DVD)Replies: 4Last Post: 24th May 2007, 09:44
