Is there a major difference between Ty's premium and value lines? Specifically I am looking at -R 8X hub printables. Supermediastore.com has them for $43 and $36 respectively for 100. Is the premium line worth the $7? Not trying to be cheap, but if I can save a little, maybe I can put the extra in the gas tank.
Phil
He is no fool who gives what he cannot keep to gain what he cannot lose. -
I bought a spindle of the hub printable Value line TY discs and lots of the discs had speckles galore near the outer edges, though some have mentioned their discs had no such issues. The other "problem" with buying the 8x value line discs is you could actually end up getting 16x discs. That sounds like a good thing unless you have a 4x burner; many of them don't support 16x discs properly.
there was just another thread on this
try a search here
personally, I'd go with the premium since $7 amounts to 2 gallons of gas
Recording Movies From Premium Channels
By mykicks in forum DVD & Blu-ray RecordersReplies: 10Last Post: 25th Oct 2010, 11:14 -
help with icons on vista home premium
By wingnut2003 in forum ComputerReplies: 11Last Post: 8th Jan 2010, 07:21 -
rundll32 prob with vista premium
By richy34 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 29th Jan 2008, 07:34 -
TMPGEnc MPEG Editor 2.0 PREMIUM
By jaffacaique in forum EditingReplies: 0Last Post: 10th Oct 2007, 03:53 -
Xbox 360 Premium or Elite?
By alintatoc in forum Newbie / General discussionsReplies: 6Last Post: 26th Jul 2007, 13:56
