when i copy a dvd then put it im my dvd player it reads no disk and the same for when put in the computer,
the burn process goes well and there definetly is something burned on the disk from looking underneath the disk.
its not specific dvds that have the problem because it happens to the dvds that i have just made a copy of like a few hours earlier and my dvd-r is supposed to be very compatable. the dye on the disk is G04, my burner is Toshiba SD-R6112 and i use nero 6 & DVDXCOPY.
most of the time it works fine but when it doesnt im ended up with coasters.
does anyone why this is happening?
It may just be a bad batch of discs. I would still try another brand. If no brand works, try cleaning your laser lens. You could also try a different burning program like DVD Decrypter or ImgBurn. If all that fails, consider replacing the burner.
Since you used Nero, did it generate a log when it burned?
Which Media player reads timecode?
By sp_key in forum Software PlayingReplies: 7Last Post: 20th Dec 2012, 15:22 -
Blu-Ray player that reads MP3's
By Megaman00001 in forum AudioReplies: 1Last Post: 21st Nov 2010, 06:55 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Question about OCR that reads Chinese
By jimdagys in forum ComputerReplies: 1Last Post: 27th Nov 2008, 07:57 -
dvd player reads "no disk"
By VINCIBLE in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Jul 2008, 12:56
