when i try to rip a dvd using any program (currently cladmdec) i get this message when opening the program:
"A valid ASPI Layer has not been found on this computer!
Authentication will not be possible through cladmdec!
Unpredictable results may occur when trying to 'rip' a dvd that's not unlocked!!!"
What does this message mean and how can i correct the problem!?! any help would be greatly appreciated!
well this means you dont have a working ASPi layer and the DVD Ripper is complaining well on CladMdecs site he has the ASPI layer installer ready to download so i suggest you go to his site and download the the ASpi layer to give you a working ASPI layer and make sure you get the corect installer for your OS
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 13:26 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 11:27 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
ASPI for XP x64
By HartsVideo in forum Video ConversionReplies: 12Last Post: 6th Jul 2008, 04:20
