Hello!
I am planing tu buy my first DVD Recorder, and need commends or meanings about these:
Sony GX220
Lite-On LVW-1105HC
Does anyone know of the movie quality from the Sony GX220 is better then the movie quality from the Lite-On LVW-1105HC?
I mean is the result from a recording from TV in an Sony GX220, better then in a Lite-On LVW-1105HC?
And this is my second question:
I have put in my LG GDR8163B PC DVD drive an Platinum (Bestmedia) DVD-RW and my drive could read it.
But I donīt know the record source from the DVD-RW.
I was even able to edit the DVD-RW with this software:
TMPGEnc 3.0 XPress
the DVD-RW.
I like to cut the commercial spots from an DVD-RW, that I recorded in this DVD Recorder:
Lite-On LVW-1105HC
My question is:
Can my LG GDR8163B PC DVD drive read Platinum (Bestmedia) DVD-RW, that where recorded in this DVD recorder?:
Lite-On LVW-1105HC
Friendly Greetings from
Moe Perry
Can anoyone write which DVD-RW DVDs are compatible when I record a film from TV on a Lite-On LVW-1105HC.
The DVD then also should be compatible for my LG GDR8163B PC DVD drive , so that my drive can read them, to edit (cut commercial spots out movies)
I also have this drive in my PC:
BENQDVDDDDW 1620 -
I have a liteon 1107HC ($99 in Best Buy) and I'm loving it. Before thios one I make the mistake of buying a Cybermedia DVR-1600 but after 2 days it began to malfuntion. I went back with my mind made up to upgrade to something with a hard drive and able to read dual format and dual layered. After looking around in the store I found that they didn't have anything with a hard drive and setle for this cheap unit that alleged to do dual format and dual layers. Well it lived up to its promeses and the cuality on my TV at least is great ( Don't record more that 3 hr on the disk) as long as you follow the guides on this site.
My media are cheap DVD-RW that I bougt 10 for $8. I gess I got luky that all the disk worked! And I do my editing eather with Cuttermaran ( Awsome freeware progarm, easy to use too. ) or TMPG MPG Edit. I could use too womble mpeg editor or Magix editor but these are for more ower editing other than just cutting & joining.
To author I use TDA or one of the GUI's for DVDAuthor.
These are a great set up.
I don't know if you read it but in one post there was a comment that said that capturing with a dvd recorder gives you same of better resolution that PC's. I completely agree if you take in consideration that is faster to set up and dosen't tie up your resourses.I want to believe....
Macrovision Firmware Lite-on LVW-5006
By drewbert73 in forum DVD & Blu-ray RecordersReplies: 36Last Post: 9th Sep 2012, 12:05 -
SONY RDR-GX220 C 13:00 Error !!
By Kirankai in forum DVD & Blu-ray RecordersReplies: 0Last Post: 4th Feb 2010, 04:20 -
lite-on LVW-5045
By pmitch in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Mar 2009, 04:44 -
Lite-On LVW-5115GHC+ timer programs problem
By smik in forum DVD & Blu-ray RecordersReplies: 2Last Post: 31st Oct 2008, 22:39 -
Lite-On lvw-5004 (europe) question
By dynalink_user in forum DVD & Blu-ray RecordersReplies: 1Last Post: 16th Aug 2007, 08:53
