I have a movie, but when I play it in MS Media Player I'm forced to turn the volume knob to max, and still have a poor audio.
I think I have the proper codecs installed.
In AVICODEC I have XVID Mpeg4 for video and "AC-3 ACM" for audio.
I've downlaoded and installed both, but still the audio is very very poor.
What can I do to enhance it?
My actual plan, after verifying audio is ok, is to join this (2-part) movie in one part with VirtualDub and burn it then on DVD.
Thanx everybody
Results 1 to 10 of 10
One method you might use is VirtualDub Mod to increase the volume. In 'Streams>Stream list', right click on the audio file and select 'Full processing mode'. Right click on it again and select 'Volume'. Adjust as needed. Click 'OK' Under 'Video', select 'Direct stream copy'. This will resave the file with the new audio without changing the video.
If you need to do more filtering or fine tuning on the audio, save it out as a WAV and use the freeware audio editor Audacity. Take the output of that and use ffmpeggui to put it back into AC3 format. Then either add that back in with the video with VDM, or if your authoring program accepts elemental streams, like TMPGEnc DVD Author, add it in then.
If you plan to take two of these files and make a DVD, don't join them. Just put them individually into a DVD authoring program and let it do the 'joining'. You avoid a lot of audio sync problems that way. -
download and use ac3filter by some russian geezer.
reboot after installing, click on it (control panel) to adjust ac3 playback volume..Corned beef is now made to a higher standard than at any time in history.
Originally Posted by Baldrick
Originally Posted by guns1inger
What do you mean when saying that since it is AC3 it is meant to be this way? That even when I'll move it on DVD I will have a poor audio?
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 16:59 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
Editing an AVI file so I am just left with the VIDEO Avi (No Audio)
By incrediblej in forum EditingReplies: 6Last Post: 26th Mar 2008, 19:16
