i just uploaded a video from my camcorder through a DV cable and i have an AVI file but only prob is the file is huge. What is the best way to convert it without loosing too much quality and getting a smaller file?
Results 1 to 9 of 9
What software are you using?Originally Posted by paythuprise
Normal process is to edit the large DV file and then encode to DVD MPeg2. You can also edit the DV format file and record it back to tape without much loss.
A wide range of software is available for DV editing, Mpeg encoding and DVD authoring.
Explain what you want to do with this file. -
Edit the video using Vegas to look how you like it.
Save as DV AVI and then open that with Windows Movie Maker and encode to WMV using settings that give you the mix of filesize and quality you're happy with. You'll have to do some trial and error...
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Vegas will also allow wmv export (see File, "render as").
http://www.kiva.org/about -
Do your friends have the Divx codec installed ?
The advantage to wmv is that pretty much anyone running windows can play it. Same for mpeg1.
Most other formats require the viewer to have the correct codecs already installed, or to go and get them.Read my blog here.
Ah - I never knew that. Then again, I don't know Vegas either.Originally Posted by edDV
Carpe diem.
converting Huffuv AVI to Lagarith AVI
By abbymat in forum Video ConversionReplies: 8Last Post: 25th Apr 2008, 04:04 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57
