??? dv-avi during capture? sure yes. the .avi file is wrong, is that what you suggest? i go to the moviemaker, and under tool-->option-->compatibility, there're some filters. should I uncheck some of them? wow, been using moviemaker for almost 5 years, never bother to look at that.
Hi guys, I got the solution. Procedure as follows
1. VirtualDub tells me the video codec for this .avi file is ffdshow video codec
2. GSpot tells me the file is at 'c:\winodows\system32\ff_vfw.dll'
3. go to the directory, and find there's this ff_vfw.dll and its unknown relative ff_vfw.dll.manifest
4. regsvr32 won't let me unregister the mysterious manifest
5. simply using the rename command to swap their identity
6. voila, the .mpv is vertically-flipped no more, and VirtualDub show the Decompressor is 'Internal DV decoder'
Hope this post can help someone who may have similar problems.
A way to insert black in frames' center and vertically push apart video?
By sincostan45 in forum EditingReplies: 5Last Post: 10th Jun 2011, 18:40 -
VirtualDubMod vertically stretching video from M2V
By Yarko1967 in forum Video ConversionReplies: 2Last Post: 17th Apr 2011, 01:16 -
captured video vertically squeezed, fix during conversion?
By krcoggins in forum Video ConversionReplies: 2Last Post: 16th Feb 2009, 16:32 -
Image is upside down/vertically flipped after conversion
By ibzomie in forum Newbie / General discussionsReplies: 13Last Post: 23rd Dec 2008, 17:33 -
Display streatched vertically
By anindyanuri in forum Newbie / General discussionsReplies: 22Last Post: 29th Sep 2008, 12:49
