I have a few cartoons that I have recorded from TV that I was going to put on DVD. I am trying to edit out the commercials but the progam I using "AVI/MPEG/RM/WMV Splitter v4.28" doesn't seem to work.
I am trying to find a program that will have a timescale when the movie is playing. example 7:30:12:13 7 minutes and 30 seconds into it, where the :13 is, is how I want to edit it. The splitter I have can edit this way, but when you save it, it only does the :12 part, even though it says I can do the :13.
I hope this makes sense and someone can help! Thanks
Most compression schemes use some variation of a Key (full) Frame followed by frames that record only the changes since the key. To cut between Key Frames you would need to re-encode the non key frames or they would have no reference frame. Therefore many simple editors only cut to the Key Frame. Since your target is DVD which is MPEG and not WMV, you might try uLead DVD Movie Factory, or similar authoring products. uLead has a 21 day free trial.
As they are WMV you could use Windows Movie Maker to cut them up, and save them to DV-avi before encoding to DVD
Read my blog here.
Asfbin 1.5 or later can do frame accurate cuts with the "-rkf" option. It reencodes only the small part between cut and next keyframe, so it can cut very fast preserving the original quality.
Cut Assistant is a GUI for Asfbin.
NOTE: if you try -rkf and asfbin gives you this error: "Decompression error: VCM decoding driver is not available", the you must install the VCM driver from here:
http://www.microsoft.com/windows/windowsmedia/de/9series/codecs/vcm.aspx
Need advice: Splitting simultaneous recordings contained in WMV file
By asawadude in forum Video ConversionReplies: 4Last Post: 10th Feb 2011, 20:48 -
How do I keep DV files from splitting ?
By RWANDREWS in forum Capturing and VCRReplies: 3Last Post: 15th May 2010, 04:07 -
splitting wmv and mpg at time codes
By silverbullet69 in forum Newbie / General discussionsReplies: 4Last Post: 19th Mar 2009, 03:42 -
Splitting AOB files
By DeadSirius in forum Newbie / General discussionsReplies: 0Last Post: 23rd Dec 2008, 16:35 -
New DVDx 2.10: shutdown count-down, WMV volume splitting and chaptering...
By Jim@labDV.com in forum DVD RippingReplies: 0Last Post: 31st Jul 2007, 05:31
