Help! I've been burning back-up copies of my DVDs for years, with DVD Shrink 3.1 to rip, and Clone DVD to burn. I read on their site there ore no more updates, and now I'm having problems when trying to rip newer movies...I tried Madigascar and The Brothers Grimm.....won't rip. Is there something else out there? I've never tried DVD decriptor. Is it the one to try???
You should have done a forum search and you would have found the answer.
But.... Download the latest version of DVD Fab Decrypter and rip the DVD to your hard drive. Then point Shrink to that file and that may be all you need. Some DVDs may require more steps than that, but try that first. If no luck, do a forum search for that DVD title and you should find some posts that tell you the required method. DVD Shrink is no longer updated, but still does a good job. It just needs some extra help with some newer DVDs.
And you can edit your post title or your post instead of making a new one to correct an error.
And welcome to our forums.
Can't play homemade DVD copies on player
By poz3614 in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2010, 07:26 -
Region Free DVD-R Copies
By Live2WinForever in forum DVD RippingReplies: 7Last Post: 22nd Mar 2010, 15:18 -
LG LHB953 not playing burned copies of my DVD's
By SMaldo in forum DVD RippingReplies: 8Last Post: 3rd Jan 2010, 22:43 -
Organising DVD copies on external HD?
By terrypin in forum Newbie / General discussionsReplies: 5Last Post: 1st Feb 2009, 09:43 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 23:33
