Hi,
I"m not sure if I'm in the right forum,it all related to TV, I have a satellite Bell Exprexx Vu similar to Star choice
The channels run from 100 to 999
To record movie from satellite into VCR which has LINE 1 AND LINE 2(where channels should be initiated) I picked up one of the channels but it fails to record....
I have connected cables yellow,white, red from Video to Audio(back of the satellite box) when I started to record, it didn't work
Anyone has Satteliite Bell , how do you record movie?
Thank you
are you sure you are not connecting to the two line IN connections that the HD and (some other model) boxs have ?
those show up on channel 00 , 01 and 02 (depending on model) as an input"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I hope you know about Satellite Bell from Canada.Originally Posted by BJ_M
I didn't connect anything, the channels are LINE 1, 2 THEN 03,IT can't go beyond channel 123 why?
Unless my VCR panasonic doesn't offer recording from satellite? -
Sounds like you set the vcr to record from channel 03 input instead of Line 1 or Line 2. I don't use the cable inputs at all anymore, just the line inputs connected to the line outs of the receiver. Set the vcr to the correct line input (video source) and press 'record'. Simple enough. Been doing this for many, many years....
Press record? the point with VCR is you can programme it when you are not there,thanks for coming outOriginally Posted by oldfart13
Doesn't matter. Your line input is set wrong. Set timer, check that your input is correct (Line 1 or Line 2). Activate timer. Simple enough. I mostly don't use the VCR for recording anymore because of it's inferior recording capabilities. DVD recorders are the way to go and since the manufacturers have stated that they will no longer be making parts for VHS recorders, the only way to go....
Canadian Satellite: Bell or Starchoice - Your experiences
By HillJack in forum DVB / IPTVReplies: 26Last Post: 4th Dec 2011, 11:03 -
Is fraps able to record regular movie video and if so is it practical?
By yoda313 in forum Capturing and VCRReplies: 0Last Post: 6th Feb 2011, 12:21 -
Help w/BD Main Movie PiP DTS-Express Audio
By infocup in forum Blu-ray RippingReplies: 4Last Post: 2nd Mar 2009, 18:14 -
How to record satellite program on dvd recorder? Thru scart cabel or RGB?
By szalaikornel in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Jan 2009, 16:05 -
How to record sound over the movie... Voice Over? Dubbing?
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 20:23
