I captured a 20 minute Mpeg1 clip using 2300 Kb/sec
bitrate (ie. XVCD fomat)
When I author using VCDEasy, it tells me that it is 20 minutes.
When I create the image in VCDEasy and burn it, I play it
in my DVD player and it shows that the clip is 33 minutes
long.
Is this normal?
Is there a way to correct this in VCDEasy or TSCV?
Correction to my previous post
In TSCV, when I create the bin file of the 20 minute mpeg1 XVCD clip, it says that the VCD 2.0 image is 33 minutes long. I haven't created any chapters or menus
Is this normal?
Is there a way to correct this in VCDEasy or TSCV? -
Funny thing is that when I play the original captured 20 minute XVCD mpeg1 clip in Windows Media Player or PowerDVD, it shows the clip as 20 minutes
It's only when I use VCDEasy or TSCV to create the bin/cue
file that the length shown for the clip becomes 33 minutes -
You have made an XVCD = non-standard/compliant VCD. They may not play properly (and incorrect playlength is common).
Your DVD player is looking at the length of the disc as IF it were a compliant disc. It doesn't know that you've tricked it with a non-standard stream. I don't think that there is anything you can really do about this.
As long as your disc PLAYs properly, I think you should be happy.
Regards.
Michael Tam
w: Morsels of Evidence -
Hi, I have a mpeg of lord of the rings which (after reading this post) must be xvcd because i made it 87 minutes but when i try to burn it nero and vcd easy think it is 98 minutes. I can't burn 98min to a cd but i can burn 87, how do i convert this non-coompliant mpeg to a compliant one.
Thank you
Justin
avi not playing full length on DVD player
By David Banner in forum Newbie / General discussionsReplies: 9Last Post: 23rd Nov 2011, 15:21 -
MPEG-TS with innacurate length
By jiastiwo@mails.cx in forum Newbie / General discussionsReplies: 2Last Post: 9th Aug 2010, 11:39 -
Change of Region Code incorrectly set on DVD player
By cashey007 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 12th Mar 2010, 21:12 -
No time shown in flv movies in VLC player or webpage
By RobRocket in forum Video ConversionReplies: 3Last Post: 19th Aug 2009, 04:39 -
Cyrillic subtitles not shown corectly on DVD player
By uher in forum SubtitleReplies: 1Last Post: 10th Dec 2007, 14:05
