I am attempting to convert a RealVideo clip to AVI. I downloaded the realvideo codec pack but I have run into a problem. To tutorial syas to place it in library>application support>fempegx. Since I am on a old G3 running OSX 10.3.9 there IS no ffmpegx file in the library for me to put it in. Any suggestions?
Tony
Results 1 to 14 of 14
They are in a file called "ripping". I used the self installer but it never made a ffmpeg dile in the library. You told me to use the older versions.
In an earlier post Major you said not to. This is confusing...
I did what you suggest and it errored out. See below:
____________
Encoding started on Tue May 16 09:38:54 PDT 2006
MEncoder dev-CVS-050215-00:40-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
CPU: PowerPC
success: format: 0 data: 0x0 - 0xa1a02a
REAL file format detected.
On the ffmpegX site download page there is also a second link pointing to a "stable build".
Not able to encode realvideo with ffmpegX on MacOS SnowLeopard
By oicram in forum ffmpegX general discussionReplies: 2Last Post: 10th May 2011, 14:55 -
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
What tool is idea to convert the RealVideo VBR into the DVD?
By coody in forum DVD RippingReplies: 1Last Post: 23rd Aug 2008, 10:16 -
RealVideo Source to MPEG2, problems.
By mattstan in forum Video ConversionReplies: 5Last Post: 4th Aug 2008, 05:06 -
converting RealVideo 10 to avi
By user543 in forum ffmpegX general discussionReplies: 2Last Post: 30th Oct 2007, 02:06
