    Apr 2006
    Grenada
    if i reduce the frames per second would it reduce the size of the video file when converting to mpeg
    How's My English?
    no, if you want to lower the size you must change the bitrate.
    Apr 2006
    Grenada
    if i lower the bitrate. would that distort the video?
    How's My English?
    May 2003
    it might if you lower it too much .... lower bitrate = lower quality = lower file size
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Lower framerate, it gets jerky. Lower bitrate enough it will turn to mush.
  6. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    If you are making a DVD with your mpeg then you must stick to the DVD standards for fps.
