if i buy ddr2 400mhz memory module for this barebone will it work?
The specs for that barebone doesn't say DDR2 memory. You'll have to get DDR(400) PC3200 or DDR (333)PC2700 type of memory.
DDR2 and DDR memory are very different. That system requires the use of DDR RAM, as budz has pointed out, so you need to get some DDR400 (PC3200) RAM for that.
I don't think DDR2 modules would even fit, and they definitely wouldn't work.
No, DDR2 is not backwards-compatable with DDR memory, they have different pins. 224 for DDR2 and 184 for DDR if my memory still serves me.
FB-DIMM are the real cause of global warming
PC memory
By alintatoc in forum ComputerReplies: 17Last Post: 17th Nov 2009, 17:24 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
Memory
By ProducerHarley in forum ComputerReplies: 1Last Post: 3rd Dec 2008, 00:38 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
