    Apr 2006
    Is this possible? Every time i try to import another clip it removes the original one.Any ideas?
    Apr 2004
    Miskatonic U
    It doesn't remove it. What you are doing is creating a new collection for each clip. If you click on the collections button on the toolbar you will get a list of collections in the left-hand pane. You can drag from one collection into another to consolidate all your clips in one location. I don't know of any way to force it to load subsequent clips into an existing collection, however I don't use it much because it has too many short-comings.
    Read my blog here.
