Hi
i have burnt a dvd where the audio plays fine on my pc but on certain stand alone players it is completely distorted.
Any ideas why??
what kind of audio? mpeg1 layer2, ac3 or pcm wav?
how did you convert to dvd? what tool(s)? -
Its was an avi file put through MainConcept MPEG encoder. I then used TMPGENC Dvdauthor to convert to dvd format.
After running the original avi file through gspot it gives the following info:
Audio 055(MP3) ID'd as MPEG-1 Layer 3
Hopefully this is the info you were looking for. -
MP3's only play on SOME DVD players. To ensure compatability, convert the sound to AC3.
i got some vhs-cassette's converted to DVD,
& when i tested them, they played fine in an LG-PLAYER,
But "no" sound in a Sony dvd-player??
any idea's
It doesn't matter what the source file had, what audio format does the encoded DVD have ? If it is DVD compliant and created by the mainconcept encoder it will be either PCM, AC3 or mpeg-1 layer2 (mp2 or mp2). MP2 doesn't play on all NTSC players, but should play on most (all ?) PAL players. If you have your audio hooked up to an amp via optical or coax digital, make sure that mpeg audio is set to output as PCM, as most amps won't decode it through the digital output.
Read my blog here.
DVD plays on only 1 out of 3 players
By mblaine in forum Video ConversionReplies: 9Last Post: 18th Jul 2010, 02:43 -
Burned DVD only plays in newer players
By rsherid in forum Authoring (DVD)Replies: 11Last Post: 16th Jan 2009, 05:02 -
Audio distortion (clipping) on computer drives/players but not dvd players
By Left/Right in forum AudioReplies: 2Last Post: 5th Nov 2008, 20:21 -
Region 1 plays on all players???
By snadge in forum DVD RippingReplies: 6Last Post: 4th Mar 2008, 16:24 -
Format free DVD-R (plays in both PAL and NTSC DVD players)
By Disco Makberto in forum Newbie / General discussionsReplies: 6Last Post: 22nd Nov 2007, 01:34
