When trying to use the link to download the SVCD2DVD programme to my PC, after paying, I get this error:Server Error in '/' Application.
A potentially dangerous Request.QueryString value was detected from the client (Email="<a href='mailto:Bpau...").
Description: Request Validation has detected a potentially dangerous client input value, and processing of the request has been aborted. This value may indicate an attempt to compromise the security of your application, such as a cross-site scripting attack. You can disable request validation by setting validateRequest=false in the Page directive or in the configuration section. However, it is strongly recommended that your application explicitly check all inputs in this case.
Exception Details: System.Web.HttpRequestValidationException: A potentially dangerous Request.QueryString value was detected from the client (Email="<a href='mailto:Bpau...").
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
HOWDO I WORK AROUND THIS?????
Something is wrong with your email client’s interpretation of the link. Instead, just open a browser window and cut & paste the text of the link into the location box on the browser & hit return.
If this doesn’t work – drop me an email & I’ll try to assist further.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 14:44 -
Error on Startup SVCD2DVD 2.5
By jenevans33 in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 05:05 -
Error reports in SVCD2DVD
By deoldeprinter in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 5th Nov 2007, 22:03 -
svcd2dvd error urgent request
By dvds2u in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 10th May 2007, 10:22
