I have just converted 4 AVIs - Using Virtual dub & Tmpeg - to Mpgs. Unfortunately I set the screen ratios to 4.3 pal. Once I converted I deleted the AVIs. When I put the Mpgs in my DVD & Turned on the tv the mpgs show in letterbox style ( I do not have widescreen TV). Is there anyway I can get the Mpgs back to normal viewing size ? - Help !!!!
You can use DVDPatcher to set the DAR flag to 16:9 if that's what you want.
/Mats -
I think you have confused original aspect ratio with TV screen aspect ratio. My reading is you want a full screen version of the video, not a letterboxed widescreen. The only way to do this is to crop and resize (and re-encode, as you don't have the originals). Of course in doing this you could be cutting off as much as 25 - 30% of the image.
Read my blog here.
VHS-DVD Screen Ratio Problem
By Ozzyjim in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Jan 2011, 22:27 -
Can't get aspect ratio 16:9 to fill the screen when play DVD movies.
By Herbert Smith in forum DVD & Blu-ray RecordersReplies: 2Last Post: 15th Sep 2010, 06:37 -
Advice needed on issue with AVI screen ratio
By Ric76 in forum EditingReplies: 4Last Post: 10th Aug 2010, 06:30 -
Split screen, keep aspect ratio and use half of 2 different videos ?
By boulder in forum EditingReplies: 10Last Post: 10th Nov 2009, 11:30 -
Screen Ratio
By green_blade in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 28th May 2007, 07:45
