Hi! I have just installed the latest ver (2.3) of VOB2MPG. Before that I ran Windows Update to make sure .net is up to date. My problem is that when I press Start (after selecting in/out directories) nothing happens. In the task manager I see that ffmpeg.exe runs at 100%, but after 1 hour I can can still not find any trace of anything happening. I run WinXP Home SP2.
Any help is appreciated as Ii understand this tool is very good, once it is possible to run it... The vob files comes from Ulead VideoStudio 7.
Any help out there?
My log file... (The strange looking stuff in the path names comes from swedish letters, but I have also tried with non swedish folder names to make sure that is not the problem)
************************ SYSTEM INFORMATION ************************
***************************** VOB2MPG *****************************
Title:
Version: 2.3.0.0
Executable: D:\media\VOB2MPG\VOB2MPG.exe
Executable size: 640 kB
Executable size in bytes: 655360
Executable CreationTime: 2006-03-14 15:49:26
Executable LastWriteTime: 2006-03-14 15:49:26
Executable LastAccessTime: 2006-05-13 02:18:43
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 2,54 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 641 MB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 4,73 GB
DeviceID: H:
FileSystem: NTFS
FreeSpace: 22,2 GB
********************* END OF SYSTEM INFORMATION ********************
********************** Input Folder *******************
04:20:20: Volymen i enhet H har etiketten HD2 DATA
04:20:20: Volymens serienummer „r 3034-3207
04:20:20: Inneh*ll i katalogen H:\Video Captures\2003 ™stersj” dvd-r
04:20:20: 2006-05-13 04:19 <KAT> .
04:20:20: 2006-05-13 04:19 <KAT> ..
04:20:20: 2003-11-29 21:19 12ÿ288 VIDEO_TS.BUP
04:20:20: 2003-11-29 21:19 12ÿ288 VIDEO_TS.IFO
04:20:20: 2003-11-29 21:19 47ÿ104 VIDEO_TS.VOB
04:20:20: 2003-11-29 21:19 51ÿ200 VTS_01_0.BUP
04:20:20: 2003-11-29 21:19 51ÿ200 VTS_01_0.IFO
04:20:20: 2003-11-29 21:19 200ÿ704 VTS_01_0.VOB
04:20:20: 2003-11-29 21:08 1ÿ000ÿ038ÿ400 VTS_01_1.VOB
04:20:20: 2003-11-29 21:15 1ÿ000ÿ038ÿ400 VTS_01_2.VOB
04:20:20: 2003-11-29 21:18 834ÿ162ÿ688 VTS_01_3.VOB
04:20:20: 9 fil(er) 2ÿ834ÿ614ÿ272 byte
04:20:20: 2 katalog(er) 23ÿ900ÿ008ÿ448 byte ledigt
04:20:20: H:\Video Captures\2003 ™stersj” dvd-r>
best regards Jan-Inge
Do you get the same issue on any other VIDEO_TS folders? (i.e do you think it is an issue with the VOBs or the tool)
I believe it is the tool. I have tried with two versions of vobs (though they are from the same movie, but I guess that is not relevant). The first vobset i tried was ripped from the ready-to-play-in-a-standard-dvd-player-disc. The second are vobs that I have saved from when I burnt that DVD.
I would suggest trying VOBs from a different disc and get back to us with the result.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Hi! I finally managed to find time to try this. It seems there is an issue with my homemade DVDs (edited, authored and burnt myself) after all. When I tried with original-DVDs, the output from them is one mpeg with the complete movie and everything in order. Just like I want them. Then I rip DVDs that I have done myself. The mpeg output files are either not complete or the different sections/chapters are out of order.
Maybe I've misunderstod how it works, but the only way I could get something at all from my own DVD was when I pointed vob2mpg directly to the DVD. When I first ripped it to ther HD and used that vob set, the result was - nothing.
I said I could get something from the DVD. That's where I am puzzled. I do get a mpeg file, but it only contains parts of the full DVD (in one case and the full movies but chapters in mixed order on the other one). The DVD contains 4 movies. In the mpeg output file I get contains the end of one of them and the beginning of another. In total 7 minutes out of about 1h. The DVD has 4 vobs.
Thanks fot you time and help!
Fairuse Wizard 2.8 Hangs
By herzeleid in forum DVD RippingReplies: 5Last Post: 14th Sep 2013, 07:53 -
AutoGK hangs when importing an AC-3...
By takearushfan in forum EditingReplies: 6Last Post: 28th Jun 2010, 07:58 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 01:53 -
Pinnacle 8.0 hangs on install
By mousetater in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2009, 18:40 -
SVCD2DVD Hangs
By chucky246 in forum SVCD2DVD & VOB2MPGReplies: 31Last Post: 3rd Jul 2007, 06:28
