I have Panasonic DMR-E60 and DMR-HS2 recorders and find that Panasonic are no longer manufacturing DVD-RAM 4.7 GB disks for the version 2.0 system. They now only make for version 2.1 which I am informed is not compatible with these machines. Can someone suggest which other makes of this type of disk that are compatible with the 2.0 system? Many sites don't give you enough information. Anyone know where there may be still supplies of the Panasonic version?
Results 1 to 10 of 10
I'm not sure what the difference is between version 2.0 and 2.1 (I would assume it's the 3x speed rating). You might try the Fuji RAM discs at Best Buy (they might be 2.0 but I have no idea since the box hardly says anything except that they're made in Japan).
I see Best Buy has just raised the prices on RAM media (they used to sell 5-packs for $10, now they're up to $12-13).
http://www.bestbuy.com/site/olspage.jsp?navLevel=4&type=category&navHistory=cat00000%2...cat65200050027 -
I am not sure exactly what you mean by version 2 and 2.1. I have a DMR-E50 and it works with the old 1X discs as well as the 2X-3X and the 2X -5X. Is it possible you have bad information? Mine is the same generation as yours.
They do have a firmware update. Possibly that will help:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloads?storeId=15001&langId=-1...ge=DVDFirmware
Also, he is in the UK so Best buy is not a source. For any other users, Panasonic direct is the lowest price anywhere in the US. I get 15 3X RAM for $18 delivered.Still a few bugs in the system... -
As you're in the UK, have you looked at SVP ?
http://svp.co.uk/products-list.php?bid=0&cid=80
I don't know if any of these would be suitable, but if it's not immediately apparent then drop them a line - SVP are very helpful. -
Thanks all for your input. I will look into all the suggestions and let you know how I get on in the next few days. The info about non compatibilty came from my local Panasonic shop I went into yesterday
Panasonic is clueless about compatibility, don't pay much attention to them. They told me DVD-R discs recorded on my E-20 wouldn't play on my E-10 or A-120, they work fine on both.
On the web site for updates I notice that the E60 and HS2 models are listed as PP at the end. Do you know if that is exactly the same as mine as I canot find PP listed in ther manuals as far as I can seeOriginally Posted by chas0039
I cannot say. Panasonic would be your best source. Here in the US they are very good at support.
After getting nowhere from Panasonic support I got some DVD-Ram 2-3 times disks and they work fine 8) I understand that pp at the end of the model number is to do with region coding. As it is not clear if the US updates are compatible with the UK models I have not updated them.
Salvaging CPU, RAM and Hard Disk from Laptop
By pchan in forum ComputerReplies: 6Last Post: 24th Nov 2011, 20:06 -
Tfr file from PC to DVD Recorder via RAM disk
By barry_w2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2010, 10:47 -
Playing DVD-RAM Video Disk On PC
By Rayvyn007 in forum Software PlayingReplies: 2Last Post: 23rd Jan 2008, 14:01 -
Burning to DVD RAM DISK and then play on your TV
By pmorris1 in forum Newbie / General discussionsReplies: 5Last Post: 25th Dec 2007, 19:15 -
How do I transfer Video from PC to DVD Recorder using a RAM Disk
By barry_w2 in forum Newbie / General discussionsReplies: 5Last Post: 17th Aug 2007, 14:14
