I just recently hit my first problem DVD using DVD Decrypter (The movie The New World). So I headed right over here to find my answer. Did some searching and found out I now might need to use DVDFab Decrypter, so I downloaded that.
Not a whole lot of things to set when using it so I just clicked start and it goes to town ripping the disc to my HD.
When it completes I open up DVD Shrink and go to open the folder to compress it and that's where I hit the problem. It tells me that it cannot read one of the VOB files. I thought it might be just that disc so I tried it on Munich and had the same problem.
I also notice that it doesn't rip any audio files into the audio folder. Just wondering if I am not setting something up right or what I'm doing wrong.
Was not able to find any other threads that touched on this in detail but hopefully I'm not the first to run into this problem.
Thanks all.
Try "fix" the ripped dvd with fixvts and then use dvd shrink.
And the audio_ts should be empty, it is used for the "DVD-Audio" format. The vob files contains both the video and audio. -
Originally Posted by Baldrick
How do I burn Video_TS & Audio_TS files using DVDFAB?
By slayerbizkit in forum DVD RippingReplies: 8Last Post: 22nd May 2011, 19:18 -
DVDFab 6 won't copy all files...
By takearushfan in forum DVD RippingReplies: 4Last Post: 20th Dec 2009, 13:49 -
Getting audio desync problem when ripping with DVDFab Platinum 4
By godfist314 in forum DVD RippingReplies: 2Last Post: 8th Jul 2008, 13:50 -
Preventing DVDFab HD Decrypter transcoding (shrinking) your files
By mazinz in forum DVD RippingReplies: 4Last Post: 30th Jan 2008, 18:08 -
dvdfab platinum dvd to ipod audio low!!!
By Jorge in forum DVD RippingReplies: 7Last Post: 6th Sep 2007, 09:59
