  1. Hi,
    I'm converting from a raw YUV to M2V using ffmpeg, but it seems ffmpeg sets the wrong bitrate in the header info of the file. I used the -b option to set the bitrate, which works, but the file has the bitrate set to all 0xffs (which is something like 1Gb/s).
    Does anyone know how I can make ffmpeg do the right thing, or alternatively, of some command line tool that will set the correct values afterwards.
    Thanks.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I think you need the -maxrate parameter as this equates to the nominal bitrate in a mpeg video stream. -b is the average bitrate.
  3. Thanks. That was the answer.
