I decrypted the VOB files without splitting,by DVD Decrypter, from DVD which looks good by my Mpeg player classic. But only first vob content,about 20 minutes, can be seen from my encoder software Mainconcept.Did somebody come with this before or have any idea of how-to
Additional information:
Winxp Intel xeon
The movie is split across all the VOBs. VOBs have a 1000mb size limit. Have a look at the vob numbering. Have a look at the file names
VTS_01_0.VOB
VTS_01_1.VOB
etc.
All those that share VTS_01_n belong to the same titleset. If you only have one movie, then it is split across the VOBs. The player puts it all back together.
If you didn't split you would only have one VOB.Read my blog here.
He said" I decrypted the VOB files without splitting "
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Just re-read the second sentaence and it making a little more sense now.
FWIW, I have just been trying to create a highlights package from material that now only exists on DVD (idiots re-used the master tapes). I was extracting just segments that I required. All four of the discs extracted without issue - multiple segments from each. But when I came to start editing, segments from one of the disc would only loop the first 30 seconds or so of a 3 - 4 minute clip. In the end I have to use virtualdubmod to srite the contents out to a losslessly compressed file, then edit from that. I still don't know why that one disc gave me problems when the same method on 3 other discs worked fine. But both clips from that disc did it.
I would suggest using DGIndex/Avisynth to open your file to see it can read the whole way through. If so, just frame serve to mainconcept and encode.Read my blog here.
Full motion menu creation software with templates?
By TVJunkieLI in forum Authoring (DVD)Replies: 2Last Post: 7th Apr 2011, 08:54 -
Can't encode VOB to MPEG-2
By radellaf in forum ffmpegX general discussionReplies: 3Last Post: 11th Jun 2008, 19:08 -
virtual dub wont load the full vob
By tvlreject in forum EditingReplies: 19Last Post: 28th Mar 2008, 20:13 -
.VOB to DVD - Do I have to re-encode?
By WuTangDvD in forum Video ConversionReplies: 5Last Post: 18th Feb 2008, 00:03 -
Dummy VOB, full disk extraction...cannot be done
By sknox in forum MacReplies: 11Last Post: 9th Oct 2007, 21:36
