I've got some Macromedia Flash cartoons i want to put into AVI or MPG. I know it will take up more space but it would be worth it.
Does anoyone know of any programs that will do this conversion and where i can get it from??
Check out a program called swf2video, worked OK for me (I did a short cartoon for a co-worker).
It uses any CODEC you have installed, so AVI/MPG should be no problem. I would suggest uncompressed AVI and then use TMPEGenc to get in into VCD/SVCD compliant format.
Only warning I can give is I seem to remember an audio/video sync problem. I fixed it, but I don't remember how (but it can be done).
Unfortuantely I don't remember wher I found it, and have since deleted it (one time need, no real purpose to keep it) otherwise I would e-mail it to you.
Do some searches and I'm sure you will find it pretty quick.
Mark -
i've downloaded the program, but when i convert it to any format, when i play it or open it up in anytihng (eg Virtual Dub), it cant recognise the file. What can I do to solve this??
Well, I dug it up off the web again and trid it.
I saved it as an AVI, Uncompressed (Full Frame), and selected "Frame by Frame" instead of "Normal" in the conversion options.
It saved a huge 400+MB file for a 400KB SWF file, but I could open the AVI in Media player with no problem (it had no sound, but that was a whole different problem).
Not sure what else I can tell you since I have had no problems and minimal experience. The only thing I can think of is - How big is the saved AVI? I know Windows and most apps don't like AVI's over 2GB...
Mark
...can it handle a converted-to-exe Flash movie? I have tons I've saved, but I converted them all to .exe's (so they can be played stand-alone).
Still looking for this file. Sounds interesting.
no authoring programs will accept my avi files
By jsdspif in forum Authoring (DVD)Replies: 11Last Post: 16th Dec 2011, 15:44 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 17:51 -
Macromedia Flash In Addition to Cache/Cookie Clearing
By Soopafresh in forum ComputerReplies: 2Last Post: 3rd May 2009, 09:34 -
Proble with Macromedia Flash
By hzgg2 in forum Video Streaming DownloadingReplies: 3Last Post: 19th Nov 2008, 04:44 -
Freeware conversion programs for AVI to DVD?
By 69ers in forum Video ConversionReplies: 9Last Post: 29th Sep 2007, 03:02
