I would like to know what you would say about this video:
Xvid file; rendered at Quantizer5 - one pass;
Multiplexed with an MP3 file at 128 kbps 44 Hz;
NTSC progressive at 29,97;
File is about 21,9 MB.
http://rapidshare.de/files/20213348/space_images_xvid.avi.html
Thanks in advance.
Could you post a couple of screen shots?, I use dialup.
No tengo miedo a la muerte. Solo significa soñar en silencio. Un sueño que perdura por siempre. .. -
i am not crazy about the font used for the title ...
images are nice - 3d and depth are great , except the plant (mars?) reddish surface looked a little to flat with the texture map used ..
you have some problems in encoding some high motion scenes -- see one of my screen shots below of a problem area (last pic)
do you need to repeat the title 3 times ?
Thanks to you both who have responded...
Abbadon, there are your pics - thanks for them, BJ_M.
About the codec: I tried Xvid at one pass and Quantizer5 (don't know why but Xvid with 2-pass encoding never worked for me).
The result at Q5 is this one: some macro or small blocks since the codec can't "follow" the action on the screen. Xvid at Q2 with one pass produces a much better result. Thanks for the input and your remarks, BJ_M.
BTW, I've got one question: does a real AVI (uncompressed) have its own alpha channel as a Targa or a TIFF file? Or .. is the alpha channel rendered in an independent file such as it is in After Effects when you choose (RGB + Alpha)?
Thks in advance.
PS:
do you need to repeat the title 3 times ? -
Not bad, although some of the edits seemed to be too quick. Some of the fly-bys etc would have benefitted from being held for a just a few extra seconds. As they stand they seem to jar for no reason. The galaxy in the first shot seems out of place. The parallax is wrong, and it feels like it is just an image on a card sliding down the screen.
The audio is distorted for me, but that is probably just because it is mp3.
I don't believe uncompressed avi has an alpha channel (I could be wrong), but some codecs do support one. I would stick with TGA files when rendering effects or 3d though. It has several advantages over rendering to avi or another video format. These include
1. Being able to restart a render at any point without having to do it all again
2. Being able to touch up single frames if necessary. If the change is minor, you can often do it in photoshop.
I only render to avi for quick tests. Finished work is always to tga.Read my blog here.
Thanks for the screen shots.
The image showing the robot is beatiful, but I am not a great fan of the XVid codec, those macroblocks in the final shot are pretty evident.
Have you tried DivX ?No tengo miedo a la muerte. Solo significa soñar en silencio. Un sueño que perdura por siempre. .. -
Thanks to all who took time to repond...
guns1inger
Abbadon, thanks so much for your remarks. On the other hand, I do prefer Xvid; it is free and I guess it's much better than Divx :P It was rendered at Q5, if it were rendered at Q2 it would look muuuuch better!
And the most important:
Thanks to Crook for his M. Falcon and R2D2;
Nabad Goksu for his own Whitestar;
Fabio Pássaro for the Imperial Destroyer
and some objects from the LW Library.
This is a Fan "Film" - and that means a Non-Commercial video
Cheers and thanks for downloading the video
Help save HDD space!
By pocketrockets in forum Newbie / General discussionsReplies: 0Last Post: 29th Apr 2012, 07:03 -
No space on disc to finalize
By Ordinary Joe2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 6th Jan 2012, 08:54 -
Too Much Space
By hech54 in forum FeedbackReplies: 5Last Post: 23rd Apr 2010, 17:10 -
Color space question
By mourya in forum ProgrammingReplies: 2Last Post: 22nd Dec 2008, 19:08 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 19:55
