I'm searching for a freeware capture program that allows me to make "stop-motion" capture using a USB webcam. It must capture any number of still pictures from a webcam and in the end must save them as an AVI file compressed with any codec available in my system. Actually, I used to do it using Adobe Premiere 6.0 which has stop-motion capture, but using as source a camcorder connected to my capture card (analog video input). But now I need to use a USB webcam (digital video input) and Premiere 6.0 doesn't recognize the webcam (unless there is a plug-in available in the net to correct it that I don't know about).
Anyway, the capture software must have a "capture" buttom to click on it with a mouse (for synchronization with a film projector) so the use of the hardware buttom of the webcam is out of question (it only takes isolated snapshots that must be saved manually).
Thanks in advance for any help!
-- Greycat.
I had a go of this years ago and got some meagre results, but I didn't persue animation. IIRC it does the things that you are after.
http://www.animateclay.com/modules.php?op=modload&name=Sections&file=index&req=viewart...rtid=24&page=1
I hope that this is helpful.Cole -
Cole:
http://www.animateclay.com/modules.php?op=modload&name=Sectio ... amp;page=1
I hope that this is helpful.-- Greycat. -
That is really odd. The only thing that I used with this program was a USB webcam.
Cole -
Take a look at CaptureFlux - it recognises my USB webcam and it can capture stills. I've never used it for what you want to do, but I figured it can't hurt to mention it...
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Cole:
daamon:
Take a look at CaptureFlux - it recognises my USB webcam and it can capture stills. I've never used it for what you want to do, but I figured it can't hurt to mention it...-- Greycat.
Usb Capture Cards and Software Motion Detection
By glvid in forum Capturing and VCRReplies: 2Last Post: 6th Jan 2012, 08:44 -
Seeking Software to Capture DOS Screen Motion and Audio
By Frank-0-Video in forum ComputerReplies: 3Last Post: 10th Jun 2011, 22:57 -
DIgital camera for Windows stop-motion software
By deesto in forum Newbie / General discussionsReplies: 5Last Post: 5th Jan 2011, 11:52 -
Stop Motion help?
By leth in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2010, 01:12 -
Stop motion softwares don't recognize capture card
By Greycat in forum Capturing and VCRReplies: 4Last Post: 26th Jul 2009, 18:22
