I'm fairly new when it comes to useing FFmpegX so i'll post my question and see if its something simple people can answer.
I have some film thats an extra widescreen format, 2.35-1 ratio that I would like to change to the more normal 16-9 for playback. I have tried padding it using the ffmpeg Xvid preset but it tends to get squashed out of shape, dispite the new black bars.
Is there anything I'm doing wrong or is there a specific setup i should be using when i want to leave the file alone, other than adding black bars?
Also is there any means of stopping FFmpegX re-encoding the video while this is going on? I dont want it to be doing a completely unecessary video change when I'm hapy with it as it is.
Any suggestions or simple 'its there dummy' pointers would be much appreciated.
Results 1 to 1 of 1
Problem padding with ffmpeg
By joesphroth in forum Video ConversionReplies: 8Last Post: 6th Dec 2011, 17:56 -
padding question for coversion to smartphone
By RdM642 in forum Video ConversionReplies: 0Last Post: 8th Sep 2010, 05:03 -
Add padding to videos
By marioval in forum Newbie / General discussionsReplies: 6Last Post: 7th Dec 2009, 06:22 -
Padding in DVD Author 3
By pepegot1 in forum Authoring (DVD)Replies: 6Last Post: 16th May 2009, 15:21 -
Resize video by padding
By tuanvn.2007 in forum Video ConversionReplies: 1Last Post: 19th Sep 2008, 09:17
