Hi.
I want to use my video iPod as my movie player at home, using an A/V cable to connect it to the TV. I have some .avi files on my computer, and also the .srt subtitle files for them.
The question is, is ffmpegX the software I need to do this job? I mean, some of the movies are divided in two .avi files and two .srt files. Can I join them into one single file and then move it to the iPod so that I can watch it on my TV?
Thanks a lot.
Results 1 to 12 of 12
What you can do is the following : first convert each avi file to "DivX mencoder" at same image size (and add its own SRT file in the filters tab). Then convert the resulting two avi files with subtitles to iPod format. Finally copy the two mp4 files with subtitles in your iPod, and watch them in sequence.
Is that DivX Memcoder, as oppsed to the ffmpeg(decode with Quicktime)?
(I'm not at my home computer...I was going to research a similar question, but found this right away---I took an avi, chose ffmpex DiVX encode, added a .srt in the filter menu, but after taking a very long time to encode, the resulting avi didn't have the subtitles on it.
Ok, I have found that using the DIVX MENCODER (rather than ffmpeg) setting, the subs get into the avi. so yay!
BUT The outputted .AVI is ignoring any settings I make to the subtitles, like font choice, size, or encoding. If I click on Preview in the Filter pane (I'm using .9t, btw) , the fonts match the settings I chose, but the actual avi, nada.
EDIT Ok, after some forum research, I found you need to replace the current Mencoder binary with This One (the one used with 9s) to get the Subtitles to change around. so Yay!
Well, that's great!Originally Posted by Scav2003
The problem is that I'm not really an expert on this... and some of the things you've just said are going on my nerves...
For example: I go to that Mencoder link that you posted and it opens a page with a lot of things to download... wich do I get? Source and Binaries, Codecs, Fonts, Skins... Then, once I get the right ones, what should I do? where to do I download them? To wich folder?
And for last, what is that "9s" that your reffer to? And the binary that needs to be replaced?
Sorry I'm really newby...
If you could spent some time answering to my questions that would be relly nice of you...
Thanks a lot.
The names of some tools get automatically linked by the forum itself, often helpful, but sometimes confusing. To get the mencoder/mplayer binaries specificly for ffmpegX, follow the links on the ffmpegX download page. To get the older version of mencoder/mplayer, that lacks new features, but handles subtitle fonts better, follow the This One link. Pick a mirror server to download from, unzip the download file. The ffmpegX app will ask for the files from the zip and put them in their right locations.Originally Posted by anamorphis
"9s" refers to "ffmpegX version 0.0.9s", which was released on 23-01-2005 (according to VersionTracker), hence the reference number in the ffmpegXbinaries230105.zip filename.
Hey man,
Is there a quckiest way to do this, at once? I mean, may I not
use mencoder to do the job directly - put the subtitles and
convert to the desired format?
No, the X264 encoder doesn't do subtitles so you have to first embed the subs using the divx mencoder and then convert the result to iPod H264.Originally Posted by trovon
I've been doing this (embedding and then converting for iPod) for a while and it's not a big deal. You may want to try these iPod H264 encoding settings, however, if you want to get the best possible quality from the videos (movies) on your iPod (when played through the AV cable to your TV):
Bitrate: add about 25-30% to the "best" recommended setting (ie, 275kb > 350kb).
2-pass (adds some encoding time but does make a difference).
4-motion vector.
Qmin: 3, Qmax: 28 (major believes the 28 is a bit excessive but I get great quality).
ME: Exhaustive (or uneven multi-hexagon). Adds some time but gives better quality.
Good luck!
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 07:35 -
No Subtitles after joining 2 avi files
By kinghlg in forum SubtitleReplies: 10Last Post: 12th Mar 2009, 06:36 -
[INFO] Embedded subtitles in .AVI files
By Midzuki in forum SubtitleReplies: 0Last Post: 24th Jan 2009, 01:17 -
Problems playing avi files with subtitles
By EPK in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2008, 22:56 -
add Optional subtitles to AVI files?
By pck76 in forum MacReplies: 1Last Post: 17th Nov 2007, 19:39
I was all happy about trying it... Now I don't know... Anyone has any other opinion about it?
