I usually use avi2dvd to convert avi files to dvd. However this only has the capacity to convert either PAL or NTSC (23,976 fps). Can anyone recommend a prog that can convert an avi with 29,970 fps to a PAL DVD??
A proper AviSynth script frameserved into an encoder. That's a lousy conversion to have to do, though. Here's a site with sample scripts for you:
http://www.geocities.com/xesdeeni2001/StandardsConversion-Preview-0.html -
There was a recent post, which for the life of me I can't find at the moment, that proposed a novel solution using avisynth. If I remember correctly, it involved speeding up the 29.976 footage to 150fps, then taking every 6th frame to get a 25 fps output. There was even a sample script.
Read my blog here.
Well that's really the only way to do it and even then the playback will not be totally smooth. Now if the source were interlaced and originated as film you could do it perfectly, but that's wishful thinking.
But all this may be beside the point. Lynxer are you aware that virtually all PAL equipment plays NTSC just fine? You probably don't need to convert to NTSC at all.
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 19:26 -
Converting 23.976 fps to 29.9 fps
By zanos in forum Video ConversionReplies: 4Last Post: 13th Apr 2008, 10:03
