Does anyone know where I can buy them? I've seen many websites that teach you how to make them, but I really don't want to do that. I need the ones similar to the ones used in the films so then I can add the lightsaber effects to them. If anyone can provide me with sites, as I've been searching for quite some time, it would really help. I'm doing this for a school project so I would need to know as soon as possible.
They sell FX lightsabers on ebay that light up and make sound effects, I don't need those kind.
Results 1 to 14 of 14
Hasbro produce cheap ones - basically a handle with a telescoping tube for a blade. My 7 year old got one for his birthday. Any toy shop should carry them or be able to get one for you. The handles are surprisingly chunky and man-sized for a kid's toy.
Read my blog here.
C'mon. Haven't you ever got to the point where the real world is so scary it's just easier to come and obvious and often dumb questions from strangers in a forum that use your brain or get off your arse ?
Some people dial 911 to check the correct temperature to roast a turkey.Read my blog here.
I have read this 3 times and still have no idea what you are talking aboutOriginally Posted by guns1inger
I think that is what he may of meant. Then again, I'm not too sure.Originally Posted by Craig Tucker
Believing yourself to be secure only takes one cracker to dispel your belief. -
if your willing to ship them from Australia.
http://www.juggleart.com/catalog/product_info.php?products_id=466&cPath=163
i used them to make mine... ok im a nerd.
made photos like this
http://home.bigblue.net.au/~mjalj/2.jpg
http://home.bigblue.net.au/~mjalj/4.jpg
micGod created man and finding him not sufficiently alone, gave him a companion to make him feel his solitude more keenly. -- P. Valery -
Just PM Yoda313, I'm sure he knows.
The thing that comes to mind was a prize on one episode of Big Brother -
Are you looking for something like this?
You can buy authentic ones at www.starwars.com. Just do a net search if you want to build one from scratch. Just get some metal casing or maybe pvc tubing and cut to size. Add some buttons and switches and you got a lightsaber handle.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If you do build them be careful about the blade if you are going to "fight" with them - use a 3/4 inch wooden dowel as they are a lot more forgiving if you hit someone than the metal pipe they used when filming the movies.
If you want to make the hilts yourself I suggest checking out www.theforce.net - the fan film section has some great guides and advice: http://www.theforce.net/fanfilms/tutorials.asp
Making a lightsaber isnt' really all that difficult, much more satisfying than buying one, and can be alot cheaper than buying (a realistic/non-plastic toy) one
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
Actually, I'd go with a heavier pipe and really try to hit each other.Originally Posted by j1d10t
When did everyone go completely insane? -
Originally Posted by smearbrick1
I guess if you like hospitals that's one way to get there
I know he asked where he could buy some Lightsabers, and most people (myself included) have so far given him advice on making them, but making them is so much more rewarding than buying them.
But if he really does want to just buy them, check out www.parksabers.com - they have some cool Lightsabers."Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073
If it's OK, I'll Buy it from You...
By rodm1974 in forum Newbie / General discussionsReplies: 10Last Post: 18th Sep 2011, 12:35 -
Which TV would you buy?
By jtrinc in forum DVB / IPTVReplies: 28Last Post: 28th Nov 2010, 09:45 -
Which BD-R to buy
By jedisinclair in forum MediaReplies: 8Last Post: 24th May 2010, 01:24 -
Will You Buy A 3D TV?
By MOVIEGEEK in forum DVB / IPTVReplies: 32Last Post: 15th Apr 2010, 15:32 -
SVCD2DVD To buy or Not to buy?
By enjohn49 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 21st Mar 2008, 11:55
