  1. i got a videologic dvd player, it come wit software 2 play ur dvd's on ur dvd. i have it runing no problem, but is there any software that will put my desttop on the tv or at least a divx player 4 it
    thanks sco
  2. If you just want to display your computer screen image on your tv than you could either use a video card that has tv out, or you could use something liek a Belkin, that will take the VGA feed to your monitor and turn it into NTSC which is what your tv will need.
    This should work OK for video and computer games but as for other tasks such as typing or web browsing, you will notice that the text will be very hard to see,very very blurry.
    A converter could run you around 100-150 maybe 200 if you buy a nice one.
