In reading many of the guides on this site I notice that when converting DVD to AVI some people keep the original width of 720 and others crop 8 pixels from right and leftfor a 704 resolution.
What are the pros and cons of each method. I understand that by cropping the black bar letterboxing from top and bottom that you that you can gain a higher bitrate especially where the black edge meets the actual video
Is there a very small black border at right and left of a 720 resolution DVD?
Thanks for your help.
From DVD ->, or AVI to DVD ? From DVD -> AVI resolution is pretty arbitrary. Most one-click convertors resize to 640 x nnn, where nnn varies by resolution/aspect ratio.
Going back the other way (AVI -> DVD) I often use 704 because the resize is slightly lower, resulting in slightly less degradation (probably invisible, but hey, I feel better about it). So long as the aspect ratio is calculated correctly, it doesn't matter much either way. Both are valid, and your player/tv will address it on playback.Read my blog here.
What's the best way to Convert 704 to 720? Avisynth or otherwise
By VideoFanatic in forum Authoring (DVD)Replies: 6Last Post: 23rd Sep 2011, 03:19 -
tmpgenc xpress auto resize results in 708 width in 720 frame.
By davexnet in forum Video ConversionReplies: 0Last Post: 27th Jan 2010, 14:49 -
720 x 576 (2703kbps bitrate) AVI for Archos 704
By drstew in forum Portable VideoReplies: 10Last Post: 31st Aug 2008, 14:49 -
704 vs. 720 burn to DVD
By brstephe in forum Authoring (DVD)Replies: 20Last Post: 11th Dec 2007, 13:16 -
1280 x 720 resize
By jimcgr in forum Video ConversionReplies: 6Last Post: 31st May 2007, 03:24
