  1. Hi
    My original size of the dvd was around 7 gb. i use vobblanker to blank few of the extras i didnt want. then the size became 5.37 gb. then i put it through dvdrebuilder pro 1.09 with following options
    CCE mode
    Oneclick mode
    Steal space from extras - selected 33%
    and thats abt it.
    My final size was 4.28 gb when we can fit maximum 4464 mb.
    i was wondering how to set dvdrebuilder pro so it outputs 4464 mb exactly.
    because 4.64-4.28 = 300 mb ish is goin waste, would like to utilize it.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Do you really think you'd be able to tell the difference?
    I never go above 4.2 GB, just to avoid the troublesome outer edge of "not top quality" media. Never missed those last 0.17 GB...
    /Mats
    Dec 2005
    Pocatello, ID
    I would avoid adjusting that as much as possible. Different movies are going to come out at different sizes with DVD-RB, so that's kind of a safe mark to make sure that you don't end up with an ISO that's still just a wee bit too big. If you still want to change it, you have to change the # of target sectors in DVD-RB's .ini file. Exactly what to change it to..... I don't know. I would do a forum search here, www.doom9.org and at www.afterdawn.com.
    -Brett
