Hello all:
I am having a very unusual sync problem while using AutoGK. I am converting some high quality files I've made down to lower resolution for use on my PDA. The source file's audio is sync'd perfectly, but the resulting file is not. Here is the weird part: The resulting file STARTS out perfectly sync'd, but gradually becomes more and more out of sync, and is a good 3 or 4 seconds off near the end. I've tried extracting the source audio as a wave and resampling, that doesn't work. Oddly enough, the video and audio come out to the SAME track length (+/- .1 or .2 seconds) I've also tried using virtualdub first to resample the source audio only and use direct stream on the video, but that did not work either. Also tried frame rate experiments too... changing them, keeping them same. I even tried converting it via TMPGenc as well. End result is the same
Any ideas? I've had sync issues that I've been able to resolve before, but this one has got me quite stumped.
Results 1 to 1 of 1
AutoGK, Audio Sync problem.
By steve_hawthorn in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2009, 00:39 -
Audio/video out of sync with autogk
By vain in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2009, 18:05 -
Audio Sync Issue with AutoGK
By KaRRiLLioN in forum DVD RippingReplies: 5Last Post: 5th Feb 2008, 15:27 -
autogk, audio out of sync
By Disa in forum DVD RippingReplies: 2Last Post: 30th May 2007, 15:03 -
autoGK subtitle out-of-sync with audio?
By cristolin in forum SubtitleReplies: 0Last Post: 16th May 2007, 00:14
