Hello,
Well i have a weird problem with playback of some video files, mainly streaming video using windows media player.
The problem is that when i stream some video from the net for example yahoo! launch video site it plays perfectly with CPU usage up to 40%, then when i try to play another video the video stutters and CPU stays at 100%. i then have to restart the PC to watch other video.
It thought it was a video codec problem, originally i use Nero's codecs to play files, i therefore tried ffdshow and that did not work, then tried 3vix. none worked.
I think it could be my graphics card but i do have the latest drivers.
Graphics Card: NVIDIA GeForce FX 5600
Media File playback problems: streamed video(wmv i thnk)
Codec pack installed: Nero
i do use firefox, same problem with both browsers, yes i do mean the second session, i would need to reboot the pc just to watch another video clip.
AHA!! I bet if you open your task manager after your 2nd attempt you will see windows media player running at 99-100%
You can unlock or stop the app right there. I don't know why it will lock itself like that. It's happened to me on accassion. Windows media player really sucks IMHONo DVD can withstand the power of DVDShrink along with AnyDVD!
What do i need if CPU usage goes 100% when video editing?
By NaHLiJ in forum Newbie / General discussionsReplies: 19Last Post: 28th Dec 2013, 19:13 -
CPU gets really hot (>100°C !) and computer turns off... Thoughts?
By sincostan45 in forum ComputerReplies: 24Last Post: 16th Aug 2010, 23:45 -
DVD shrink using 100% of cpu power, how is that possible?
By aslan in forum ComputerReplies: 10Last Post: 24th Sep 2008, 09:51 -
Stop VLC from using 100% cpu time
By rock.freak667 in forum ComputerReplies: 13Last Post: 4th Apr 2008, 20:56 -
CPU usage goes to 100%
By Tbag in forum ComputerReplies: 21Last Post: 18th Jan 2008, 09:59
