hi, i want to know how can i made some modifications on a dvd menu without changing anithing in it. i want to add an aditionnal language track and subtitles with the vobs of the original dvd, and add the needing buttons in the original menu (with out re-authoring it) to make it work.
thanks to answer
Can't be done. Not without reauthoring.
/Mats -
ok, so how can i reproduce the menu and it's funtions to be exactly the same to the original. and what will be the right program(s) that i will need to do that.
thanks to answer -
No idea. I'd never dream of doing it. I'd guess any DVD authoring app with subtitles support would (with your help and knowledge) be able to do it, provided you take the original DVD apart completely. Anyone else, industrious enough?
/Mats
Can do BDRebuilder a mkv file with more than one language tracks
By videoten in forum Blu-ray RippingReplies: 4Last Post: 4th Jun 2010, 14:39 -
Can you add a second language audio track on DVD workshop 2
By uncle mikie in forum AudioReplies: 1Last Post: 14th Jan 2010, 23:22 -
DVD with 60 tracks back to multple mpeg files
By illpeeonu in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2008, 13:25 -
Add a language menu to a DVD
By hellbound in forum EditingReplies: 0Last Post: 6th Aug 2008, 10:01 -
multiple language tracks in iTunes
By Patrick_H in forum DVD RippingReplies: 0Last Post: 15th Feb 2008, 11:12
