What is the lowest compession you would go down to?
Is anything under 64kbps not recommended?
Results 1 to 12 of 12
It all depends on what you're using it for. MP3's do not sound good below 128kbps but WMA sounds good at 64kbps and so does Vorbis.
I capture the files by using windows media player and then I convert it to MP3. I tried 32kbps but the sound is alful but to me 64kbps and 128kbps sounds exactly the same.Originally Posted by CaptainVideo
I'd say it's subjective... 64kbps might not sound bad to you, but horrible to someone else. I've heard about people who refuse to go below 320.
If cameras add ten pounds, why would people want to eat them? -
No doubt you are right. I just want to get about 50 classical albums on 1 CD.Originally Posted by Ai Haibara
mmm...the fact that it is classical music will probably warrant a higher bitrate unless you want it to sound terrible. What is your application? If you want something for home you can get dvd players that play mp3's burned to dvd. If it's for a car mp3/wma player then you might want to make sub-categories for your music and burn to seperate cd's.
It is a pioneer 433H. It won't play MP3 format on DVDs only CD. I have tested the files on the computer, they sound okay. I guess I am not fussy. Mine you I drew the line at testing 32kbps, that did sound alful.
For MP3s, anything less than 160-192 kbit/s would probably mean that you will hear audible encoding artifacts. YMMV.
I would only use very low MP3 bitrates for specific material - e.g., spoken voice.
Regards.Michael Tam
w: Morsels of Evidence -
This may help you understand mp3 a little better.
http://en.wikipedia.org/wiki/MP3 -
i would use either cdex or eac (exact audio copy) to create your MP3's
use VBR
192kbit/s is considered near CD quality
and use more than one disc for your 50 albums -
I think Sifaga is correct go with 192kbs, it sounds much better. How are you going to write small enough to write fifty different titles onto the surface of one disk cover anyway?
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 07:01 -
Making CD-R compilations: Best mp3 splicer freeware/cheapwear suggestions
By Krelmaneck in forum AudioReplies: 26Last Post: 2nd Oct 2009, 01:50 -
making an mp3 dvd
By cL0N31 in forum Newbie / General discussionsReplies: 17Last Post: 30th Mar 2009, 11:32 -
How to merge audio file(mp3) and a video file (flv)
By suresh3484 in forum Video Streaming DownloadingReplies: 0Last Post: 20th May 2008, 01:15 -
Making an audio dvd with wav & mp3 files
By wwervd316 in forum AudioReplies: 1Last Post: 18th Mar 2008, 22:41
